DXF
DXF
Hi folks, can someone explain to me the method for loading a DXF file into the Contour Editor. Thanks.
Gary Puckett
Company Name: The Woodworkery
Re: DXF
Post by Gary Puckett »
Rick,
Can you do that and if you can don't you have to convert it to a stl file?
Re: DXF
You just click the folder icon, find the DXF file you want and load it.
I think the DXF must be 2D in the Part Editor.
Re: DXF
Hi Rick
Last night I started a Cabinet for Joe Lumber that I do alot of custom work for him.
I am not sure what the guy is going to do with it :?:
I had to make up a DWF File for it in DeltaCad Like Dan said it is in 2D
What would you charge the lumber Co :?:
Hi Dan how are you doing I almost made it one year Going in to the BIG "H" Sept.17
My right Carotid Artery is 81% :wall: Left is 52% they are just doing the r :cry: ight
How I did it in Zip File
EC dxf File.zip
(2.42 MiB) Downloaded 299 times
Re: DXF
Thanks guys, I saved the drawing to a new sheet and it worked fine.
Re: DXF
George Davidson wrote:Hi Dan how are you doing I almost made it one year Going in to the BIG "H" Sept.17
OUCH!!! What are they doing...angioplasty? Are you having the other done later?
Good luck with it George. I got a feeling I will be going through physical therapy or cortisone shots for a while before any surgery. My new doc is supposed to be a lot less agressive when it comes to surgery, resorting to it only after everything else has failed. The last several days my back hasn't bothered me much at all so I don't mind the conservative treatment as long as it doesn't get back like it was.
I guess in a few weeks you and I can sit here and bore everyone with our moans and groans, eh? :beer:
Re: DXF
It don't look so bad
The last 5 years I was in the "H" in June I all most had a year :x
It's funny 3 of the builders we do all there trim and kitchen have had I done by the same Doc.
They all play golf together on Wed.They said they will take me to play golf I don't even know what end of the stick
to use :beer
Two signs are Numbness or tingling on one side of the boby
I told the Doc.I am tingling on my right side now he said are you sure I said yes Doc.my wife is seating on the right side of me now :joker: :joker:
