problem with making jeps of cabinets
Re: problem with making jeps of cabinets
Rick Palechuk wrote:That's interesting, I just set my res. one spot lower and the Jpegs work ok now. Unfortunately I can't live my life in that resolution. It's killing me Spock killing me!!!!!!!!
Hmmm...very interesting indeed. What resolution was causing the issue and what corrected it?
I am (and have always) using 1024x768.
Paul Ellis wrote:Could this problem perhaps have something to do with the combination of resolution/refresh rate (Hz) of the video card? And perhaps if you have interlacing activated or not?
Have a look at this http://www.pcguide.com/ref/video/modesRefresh-c.html
Perhaps a bit technical, but I think worth looking into. I shall try different settings and see if I get any jpegs with the size dialog box included.
(I have an ATI Radeon 9550 with 256mb display card)
I don't think refresh rate would have anything to do with it and unless you have a really old monitor it is probably non-interlaced. I don't think interlacing would have anything to do with it, but then I didn't think resolution would either. :wink:
Well, I just tried 1600x1200 and didn't get the dialog box in the image (couldn't see what I was doing either :wink: ).
I have mine set at 1024x768. NVIDIA GeForce 8600
Is that when you do get the dialog box in the image or not?
Yes, That's where I have them set normally. 960X600 made the box disappear.
Really strange...I tried numerous resolutions (larger and smaller) and never got the dialog box in the image. :?: :?: :?:
Daniel Vonderheide
Post by Daniel Vonderheide »
just to update:
I worked with a customer that was having the same issue with the jpeg size dialog box showing up in his pics. I had him turn down the hardware accelerations in his screen settings and it took care of the issue. Please try this and let us know if it cures the issue for you.
Right click on the desktop and select properties.
Go to the settings tab and click the button labeled "advanced".
Select the tab labeled "troubleshoot". You should see a hardware accelerations slider. Turn it down to approx. midway.
Apply these changes and then try to create a jpeg in ecab.
I don't think it is hardware acceleration as I have always had mine set to full.
Rob Perry
Location: Qualicum Beach, Beautiful British Columbia, Canada
Post by Rob Perry »
I just tryed turning down the hardware accilerator to 1/2 way down & it seemed to almost do the trick exept for a small square showing up
Reselution is set to 1280x1024\
Rob
That's what gets me--I've tried every resolution between 800x600 and 1920x1440, full hardware acceleration, different computers, different video cards, etc and I have never had it show up. I just can't cause it to happen while others can't prevent it.
Its crazy... :wall: :joker: :wall:
