Cutlists & Assemblies
Steve Williams
Post by Steve Williams »
Hello All
I have grouped three base cabs together and and applied end.
When I Hit "C", do I get the custlists for all the cabs or just one of them and is the ae included?
Thanks for your help
Steve
David Egnoski
Re: Cutlists & Assemblies
Post by David Egnoski »
If you created an assembly, you should get a cutlist for the whole thing. If you have any cabinets selected when you hit "C", you'll get a cutlist for what is selected. If no cabinets are selected, you get a cutlist for the whole thing. Rather long winded but should be accurate.
Dave Egnoski
Richmond Cabinet & Millwork
Steve Williams
Thanks David.
Would that include the applied end ( it is a cab not an assembly )?
David Egnoski
Yes, it should include the applied end.
Glad to help.
Dave Egnoski
Justin Melhiser
Post by Justin Melhiser »
Steve
Make sure when you add the applied end, when you select the end to add that it is build in house. If it is set to alternate source then it will not add it to the cutlist.
