Installed 5.43 a few days ago and ran into a problem with pocket cuts. On SOME, not all, of the pockets, the cutter runs half the diameter of the cutter into the part when running the cleanup pass, resulting in a clean pocket, with a half circle cut into the material at one end of the pocket.
Also, after updating CN, I discovered that my tool group settings had all been deleted. All of my material-specific tool setups are now gone.
I have had to revert to a previous version in order to get pockets to consistently cut correctly.
problems with CN 5.43
Mark Hesketh
Ryan Hochgesang
Re: problems with CN 5.43
Mark,
We are currently looking into this situation, however, if you'd please send your supporting files to program@thermwood.com we can also use your files for testing. We would like to see your design file along with the Export from control nesting.
Thanks!
Thanks!
- Georgi Baltov
- Company Name: Top Notch Cabinets
Wow, this is going bad. I haven't nested anything with 5.43 yet. Only a couple of sheets with dovetail dbxs. I will revert to 5.41 tough. Don't want to risk it. Too many ppl found all different bugs.
Top Notch Cabinets
http://www.topnotchcabinets.com/
