Please help us with the following issue:
When starting the controller it freeze after windows has started and the thermwood software is loading (version 6 image)
Then the PC is frozen, even CTRL+ALT+DEL does not work.
Following calls to your tech support
We have :
1- check green fuses, the 2.5A was burned and we replaced it, it is OK now
2- delete log file (plchist.thm, mclock.bin, mclog.bak)
3-re-install thermwood software on C: drive
4- check RAM chip (remove clean, reseat)
5- remove non-essential component on MB (modem, unplug keyboard and DVD drive and use standard external keyboard
6- checked voltages from PC power supply.
None of these worked.
Any other suggestions.
Thanks.
