max penetration and speed problem
Nemanja Vujkovic
If the max penetration is set up so there is more than one outline cut(multiple passes), the outline speed of the first cut is the same speed as the speed of skin removal if the part is on the small side. This is not a big problem, but it uses more time than needed and it can be noticed when cutting 5x10 sheet full of small parts and the sheet is 1 1/8" thick. I have it set up where the bit can penetrate .8" at a time.
This is what i got:
1st pass: 142ipm
2nd pass: 800ipm (full speed)
3rd pass(skin removal pass): 142ipm
Is there a way to speed up the 1st pass to full speed?
Nemanja
This is what i got:
1st pass: 142ipm
Nemanja
David Hall
Re: max penetration and speed problem
This problem has been acknowledged by Thermwood.
Until it's fixed you can work around it by setting your "Max feed size" smaller so the speed reduction doesn't kick in.
Dave
Dave
David Hall
On second thought, this may not be the same problem... but the "max feed size" may still get you around it.
Dave
Dave
Nemanja Vujkovic
Thank You David, but the pars are 3/4" wide, so if the speed reduction does not kick in the parts will move. I think the best thing to do is to wait for it until it's fixed.
Nemanja
Nemanja
- Larry Epplin
Please post an export of Control Nesting with this configuration. We will insure it is resolved. Thanks!
Nemanja Vujkovic
Larry,
here are the files. Sorry it took a little longer for me to post them.
Nemanja
Nemanja
- files.zip
- this are all the files(.dxf, .cnc, and export file)
- (63.16 KiB) Downloaded 3401 times
- Larry Epplin
Thank you for the files. This will be resolved with the next update.
Nemanja Vujkovic
Thank you Larry for your help.
Nemanja
Nemanja
