Posts: 1585 Joined: Tue, May 17 2005, 1:16PM
Post
by George Davidson » Fri, Mar 27 2009, 6:15AM
I made a molding rack for our shop.
Cut list tells me 3-Sheet of 1/2" plywood
Batch material tells me 2- sheets
The batch is right
Here is another batch
Material List_4=Sheets.jpg (86.38 KiB) Viewed 6508 times
Material List_2=Sheets.jpg (52.53 KiB) Viewed 6509 times
Cut List.jpg (100.36 KiB) Viewed 6508 times
Post
by George Davidson » Fri, Mar 27 2009, 6:24AM
Here is the Rack in ZIP File
It is the rack back of the panel saw.
Made of 1/2" plywood and exter Plasic Balusters
How the rack locks.jpg (53.19 KiB) Viewed 6499 times
Molding Rack back of Panel Saw.jpg (74.81 KiB) Viewed 6504 times
Molding Rack.zip
(347.44 KiB) Downloaded 245 times
George Davidson on Fri, Mar 27 2009, 6:34AM, edited 1 time in total.
Posts: 5852 Joined: Thu, Jul 28 2005, 10:18AM
Post
by DanEpps » Fri, Mar 27 2009, 6:31AM
The cut list BEFORE nesting is based only on total square inches and cannot be relied on for accuracy. ALWAYS nest before producing a cut list.
Post
by George Davidson » Fri, Mar 27 2009, 6:36AM
Thank You Dan
I for got you did say that before
Post
by DanEpps » Fri, Mar 27 2009, 6:41AM
Maybe the cut list should have a disclaimer to that effect if it is produced pre-nest?
Post
by George Davidson » Fri, Mar 27 2009, 6:45AM
I am not sure what I did it still comes up with 3-Sheets cut list
Post
by DanEpps » Fri, Mar 27 2009, 6:47AM
Did you run the cut list from the nest?
Post
by DanEpps » Fri, Mar 27 2009, 6:53AM
I gives 2 sheets for me, both before and after nesting.
Post
by George Davidson » Fri, Mar 27 2009, 7:05AM
Thank You Dan
So I get the right cut list just when I am in the batch.
I was thinking if I batch it and came out into Cabinet Editer I would get the right cut list then
Post
by DanEpps » Fri, Mar 27 2009, 7:14AM
Batch it, nest it then create the cut list while still on the nest screen.
Post
by George Davidson » Fri, Mar 27 2009, 7:18AM
I said batch I sure of said (nest screen)
I need more coffee
Post
by George Davidson » Sun, Apr 05 2009, 6:22PM
Molding Rack Done
I can't get my self to put trim on the rack if it could just stay like that
Molding Rack 4-5-09.jpg (41.22 KiB) Viewed 6309 times
