Part Editor
Paul Amos
Company Name: Fretworks
Part Editor
Post by Paul Amos »
I am trying to create an arched cutout to a L/R stretcher but the Part Editor says that this part type is not supported .....Any suggestions.
Paul
Nick M Singer
Re: Part Editor
Post by Nick M Singer »
Make the stretcher out of a display panel
Rick Deskins
Company Name: Thermwood
Re: Part Editor
Post by Rick Deskins »
Wait for v6, or use a display panel instead of a stretcher. (Note: display panel will not resize when the cabinet resizes).
Rick Deskins
Paul Amos
Re: Part Editor
Post by Paul Amos »
Thanks for the quick response,
I will have to use it with the stretcher and blind dado's so that it resizes with the cabinet, then re-machine the arch after.
What is planned for V6 and when will it be released ? No pressure.
Paul
Re: Part Editor
Post your cabinet Paul, maybe there is something else that can be done.
Rick Deskins
Re: Part Editor
Paul Amos wrote:What is planned for V6 and when will it be released ? No pressure.
http://www.thermwood.com/forums/viewtop ... f=3&t=9042
Rick Deskins
Paul Amos
Re: Part Editor
Post by Paul Amos »
Rick Palechuk wrote:Post your cabinet Paul, maybe there is something else that can be done.
Rick,
Here is the cabinet, the L/R section will have doors the center section is open with an arched rail.
Any suggestions would be appreciated.
Paul
123.esj
(12.02 KiB) Downloaded 1106 times
Magical Snap - 2009.04.15 17.29 - 005.jpg (31.29 KiB) Viewed 21559 times
JohnLashuay
Re: Part Editor
Post by JohnLashuay »
Paul,
As was mentioned before, your best bet is to use a display panel or display cube and take it to the part editor.
Good Luck!
-John
http://www.rylexonline.com
Thermwood CS 43
Re: Part Editor
Paul
I used a sheet stock face frame and removed everything but the top rail with some insets. I also used negative insets on the left and right sides as well as the deck and toe kick.
The arch has constraints so you can re-size.
I forgot to do your top like you have it.
I couldn't open your job file, it is only 12 KB
Re: Part Editor
Here is a shot with the top overhang
Paul Amos
Re: Part Editor
Post by Paul Amos »
Kerry,
Thank you, that is exactly what I was looking for.
Paul
JohnLashuay
Re: Part Editor
Way to go Kerry!! All the rest of the posts say it can't be done and you prove us wrong. :oops:
Great work as usual :wink:
-John
Thermwood CS 43
Rick Deskins
Re: Part Editor
The only thing the face frame solution does not allow is the blind dados. keep this in mind.
Rick Deskins
Re: Part Editor
Would this help
Test 4-16-09.zip
(98.54 KiB) Downloaded 986 times
Test Cab 30 x 34. x 24_2.jpg (98.04 KiB) Viewed 21354 times
Test Cab 30 x 34. x 24.jpg (95.21 KiB) Viewed 21353 times
Paul Amos
Re: Part Editor
Post by Paul Amos »
Hi George,
What part did you create it from ?
Did you use the contour editor to create the shape ?
Many thanks
Paul
