end panels
Patrick Russell
end panels
Post by Patrick Russell »
I'm trying to place a end panel on a pantry cabinet side. I know how to do it from custom layout, but I don't just want a single raise panel on the cabinet. I want to place four raise panels on this cabinet. I tried creating a cabinet the same size of the end panel that I need and placing double doors on it. When I remove all the parts but the doors my cabinet disappears. Can someone please help :wall:
Gary Puckett
Company Name: The Woodworkery
Re: end panels
Post by Gary Puckett »
Patrick,
Open your cabinet in the cabinet editor, then select a raise panel door, size it to what you need it to be then place them on the end panel. If it is just for presentation purposes you can over lap the rails and styles of the doors to create the look of one panel that may have four raise panels on it. Once you are done it will look like one panel
Be sure to associate the doors to the cabinet.
Re: end panels
With the cabinet in the Cabinet Editor, click the Load Item icon (folder on lower menu bar). On the displayed dialog, click the Doors/Drawers radio button on the left side. Enter the size and click the Select Door button. Pick the door you want to use and manually move it into position. You can copy and paste that door as needed but you will have to add another if the size is different.
Patrick Russell
Re: end panels
Thanks guys
Re: end panels
Hi Patrick
Try the way Dan shows on his Video
http://www.ecabworld.com/Media/Video/Cr ... Panel.html
It is very easy the way he shows it
Re: end panels
It took me about 7 m to make this side panel just now
Side panel 23.25 x 84.jpg (29.9 KiB) Viewed 27888 times
Patrick Russell
Re: end panels
Thanks George,
This is great, much faster and very clever! :beer:
John J. Desmond
Re: end panels
Post by John J. Desmond »
Here is another question. How do you actually make a raised panel or a double panel door that will actually show up on the cut list? I understand how to do what the video tutorial shows for presentation purposes but actually doing it is another story. So, eCab experts, how do we accomplish this?
John
Re: end panels
Patrick, this is an assembly of two cabs. The first cab is a standard tall, the other is with all the parts removed except the back and fixed shelf. The back material is 1/32" thick called DNC Thin (Do Not Cut). The shelf is DNC. The cab depth is 1/16". The shelf is needed to give separation for the doors. This item is fully re-sizable, and shows correctly on the cut list.
John, we have been crying for that for a while now. :wink:
Tall w Panel.jpg (34.95 KiB) Viewed 27844 times
Tall with panel.esa
(260.02 KiB) Downloaded 1648 times
Re: end panels
John J. Desmond wrote:Here is another question. How do you actually make a raised panel or a double panel door that will actually show up on the cut list? I understand how to do what the video tutorial shows for presentation purposes but actually doing it is another story. So, eCab experts, how do we accomplish this?
John
If you manually add doors as end panels and select "Build Inhouse", they will be on the cutlist.
Re: end panels
Here is my side panel
small 15 x 86
Re: end panels
I just added another video showing how to use a door as an end panel. You can find it at eCabWorld Training Videos.
Re: end panels
I make all my door in shop
Here is what I have been doing for my end Panels
Is there an easyer way to make them for the shop
End Panel_ 24 x 34.5_Panels 9.75 x 30.5 x .75.esa
(748.02 KiB) Downloaded 1658 times
End Panel 24 x 34.5 x .75_2-Panels.jpg (60.63 KiB) Viewed 27794 times
Cut List_End Panel_24 x 34.5 x .75.jpg (103.71 KiB) Viewed 27794 times
