I am starting scratch with a kitchen. I want all my 1/4" backs to fit in a dado, and have a 4" cleats behind them. I want these settings for the whole kitchen. I am designing the kitchen, and have played with offsets and have the box looking like I want it, but I don't think the sides, deck and top will dado. How do I set this, and I don't see a check box for a cleat to go behind it. Is there a way to make this the default for the whole job.
Also I want detached 4" toe kicks. When I click the setting, my rendering shows no toe kicks and when I nest the parts, there are no toe kicks...Any advice? Justin
creating uniform
Justin Rank
- Company Name: Coastal WoodworX
- Gary Puckett
Re: creating uniform
You can do all the things you want in constuction settings in the cabinet editor.
- DanEpps
- Company Name: Dan Epps
After you create the cabinet to suit your construction methods, save it as a "seed" cabinet in a new library (just type over Standard" for the name).
You will have to manually add a stretcher on the cabinet to serve as a cleat.
When you use a detached toe, you can add the toe to your room or batch by browsing through Standard Cabinets and loading the Std Detached Toe.
