Changing the default sheet location setting?
Dale Wills
Company Name: none
Country: AUSTRALIA
Post by Dale Wills »
Can someone help me out here........trying to find the setting in control nest where you select where you want your default sheet location. Where can I find it?
Dale
Ryan Hochgesang
Re: Changing the default sheet location setting?
Post by Ryan Hochgesang »
Hi Dale,
You will want to go into Control Nesting, select SETTINGS button, then select FENCE/FIXTURE LOCATIONS button.
Dale Wills
Company Name: none
Country: AUSTRALIA
Can I select the locator bar as my sheet locator here?
Dale
Ryan Hochgesang
Yes. You would set this up under the Flip Operations title.
Dale Wills
Company Name: none
Country: AUSTRALIA
I think we may be off track here. Basically instead of nesting from the G901, I want to nest from the G902 and use the flip operation fence. I have pre-cut panels in which I need to do some machining on the inside. So I need to locate then using the flip operation fence and also don't want any outline cut performed. How do I do this?
Dale
Ryan Hochgesang
You will need to go into Control Nesting SETTINGS and select the "No Outline Cuts" option. Also in the SETTINGS area, you will need to choose the Nesting Parameters button and ensure that Add Part Clearance and Collar are set to zero.
Dale Wills
Company Name: none
Country: AUSTRALIA
Thanks for your help. I may be wrong here but this isn't how you change the default nesting position to the G902 is it?????
Basically instead of nesting from the G901, I want to nest from the G902 and use the flip operation fence. I have some pre-cut panels in which I need to do some machining on the inside. So I need to locate them using the flip operation fence and also don't want any outline cut performed. How do I do this?
I undestand the 'no outline cut' but not sure how to nest a pre-cut to size part in the G902 position.
Dale
Ryan Hochgesang
Go into Fence/Fixture locations button within SETTINGS and simply change the Sheet Operations, Fence Location to G902 vs. G901. You just place the cursor in this dialogue and type it in. Hope this helps.
Paul Ford
Post by Paul Ford »
Dale,
Also make sure while you are in nesting paramaters that you tick the selection box for Nest to edge of sheet.
All the settings you change in here will stay the same until you change them again....
Ryan Hochgesang
Yes, this will also need selected, thanks for adding that in Paul.
Will Williamson
Post by Will Williamson »
To change the location of the G902
What you are looking for is located in the M999 macro .
Go to tool length measuring file and open it
arrow down to the M999 line (about 4 or 5 lines down)
push the blockstep+ to enter the macro
arrow down to the set G902 line (make a note as to what the original setting is so that later on you can reset it if necessary)
hit Tab and change the info
hit enter
hit the end key
push blockstep +
And that takes you out of the macro
home the machine
Will
http://www.willmade.com
Ryan Hochgesang
In addition to Will's posting:
If your Thermwood control software is V7.2.0+, then you will access the Machine Variables Table to edit the actual location of the G901 and/or G902. To access this table, go to top menu bar on THM control screen and select EDIT, Machine Variables.
