Forgot how to export
Gary Puckett
Company Name: The Woodworkery
Post by Gary Puckett »
I seemed to forgot how to export my cutlist to excel. I thought all you did was create a cutlist and it gave you a choise to export to excell. What am I missing?
Dickey Beckham
Re: Forgot how to export
Post by Dickey Beckham »
No you have not forgot, thats the way, thats the way you do it.
Gary Puckett
When I create a cut list I don't get the option to expot to excel. I am sure I have done this sence I got Vista. Where the heck did the Export to Excell option go :wall:
Gary,
The link should be Here
Gary Puckett
Kerry ,
That's the problem the link is not showing up. I have tried to restart my computer and that did nothing. I have closed down eCab. and reopened it and still the link will not show up. I have not tried to reinstall the update for fear I might lose eCab all together.
I am sure I was able to export in the past.
Gary,
I will bet you are correct about it being a Vista thing.
Rick Deskins
Company Name: Thermwood
Post by Rick Deskins »
Gary,
Do you have this file on your hard drive c:\Program Files\Thermwood\eCabinet Systems\temp\cutlist.xls? If you delete it by hand and then rerun the cutlist, does it show up?
Rick
Rick Deskins
Gary Puckett
Rick,
It happens with any cabinet.
Gary Puckett
Should I try and rerun the latest patch? I tried to export on my lap top ( witch is Vista also) and it works just fine.
Rick Deskins
Gary Puckett wrote:Should I try and rerun the latest patch? I tried to export on my lap top ( witch is Vista also) and it works just fine.
Did you try deleting the file I mentioned in my previous post then run the cut list?
Rick Deskins
Gary Puckett
Yes I did and it did nothing even the standard cabinets will not let me export to excell
Gary Puckett
Should I reinstall the disk?
Gary Puckett
It seems like the program lost the Excel link. Is this possible?
Gary,
I would give the eCab guys a call before I re-installed. As I remember you had a lot of trouble installing this on Vista.
Personally I a would just wait for the release of V6 and for now copy my job to the laptop to export since it is working there.
Rick Deskins
There is only three reason for the link not to show up.
1. it can not delete the temp\cutlist.xls file. (cutlist.xls is readonly or ecabinets is not being run as admin)
2. it can not open the excel driver to create a new xls file (i.e. excel or excel viewer is not installed on the pc)
3. ecabinets does not have admin rights to create the xls file itself. (Are you running ecabinets as admin?)
Rick Deskins
