Hi Everyone,
Im trying to load an assembly, from the custom layout screen to the Line Drawing Editor, and add dimintions, notes, ect. but when I do the assembly will not remain highlighted green. It flickers for a second then returns to black This is driving me crazy, I know its something simple I'm over looking.....hopefully. I've poored over the "Nearly Completed Guide", and found nothing, any help would be greatly appreceated.
Rick NesSmith
I believe I followed your steps, but could not duplicate your problem.
From Custom Layout, I selected an Assembly. Then clicked on the Line Drawing Editor and selected take Assembly.
In Line Drawing Editor, select the Assy icon. Move your cursor of the assembly (changes to magenta wireframe), then left-click on it (changes to green wireframe). If you have Cab selected it I select just a cabinet if there is one, or Part, just a component. If you have selected Room or Wall there will be nothing to select.
If you've followed those steps, then I would suggest that you post the assembly file to the forum.
Also, I'm sure that someone will want to know a ton of information about your computer, graphics card, and operating system. If you are performing the procedurally as I've outlined, it typically points in this direction.
