Good day We will be installing a M67-105 this month and I am looking to install some sort of a dust collection system to the machine. This machine will be used for 3 axis work when our M45 is at capacity. When we need 5 axis work done our primary use will be carving EPS or sign foam 4' x 8' sheets.
I'm think of fitting a skirt system from a M45 3 axis machine for use when we are in the 3 axis mode and removing it when in 5 axis mode. I am also thinking that we could use a different system for the 5 axis mode. Perhaps vertical 8" walls mounted to the bed perimeter with some collection ports installed into the rear wall. Any thoughts or suggestions would be a good thing. Thanks for your help.
Bob
Dust collection for M67
Moderators: Mike Iubelt, Jason Susnjara, Clint Buechlein, Mike Iubelt, Jason Susnjara, Clint Buechlein
Bob Gregory
Ryan Hochgesang
Re: Dust collection for M67
Hi Bob,
The 8" tall wall setup sounds like a pretty good idea. Also, I've looked into C67-105 and this machine shows up as containing a dual ended spindle. If you contact Thermwood retro dept., they can give you information on a collection device that will mnt. directly to the router. The following link has some info. regarding the system I'm thinking of:
http://www.thermwood.com/twood_site/pag ... ector2.pdf
Retrofit Dept. Contact Info.:
email: retrofits@thermwood.com
or
Call: 1-800-221-3865 (Ext. 251)
or
Bob Gregory
Thanks Ryan I spoke to Jeff in the retro fit dept and what they have will not work. Our machine which has an HSD spindle with the ATC storing tools in the left leg. The available dust collection rig will only work with tool bar stored tools and not leg stored tools. So it looks like the 8" wall idea will be our solution.
Bob
Bob
