Version 6 Build 2 – Can’t Open Corner Cabinet
Sean Jakob
Company Name: Sean Jakob Cabinets
Post by Sean Jakob »
When I try to load the attached corner cabinet (which was created in version 4 or 5) directly into the cabinet editor via the load screen, eCabinets hangs at the “Applying Part Editor / Constraint Data” step.
If I load the cabinet into a batch cabinet list or into a room layout, then click on the cabinet to take it into the cabinet editor, it loads OK, but I'll be buggered if I can get to too load direct from item menu into cabinet editor.
any suggestions anyone?
Corner cabinet won't load from Item window
Corner Cabinet.jpg (10.07 KiB) Viewed 3345 times
Corner Cabinet.hsf
Corner Cabinet Won't Load
(1.15 MiB) Downloaded 331 times
Re: Version 6 Build 2 – Can’t Open Corner Cabinet
Sean,
Sean,
I placed your cabinet in a room and took it to the cab editor from there, opened construction settings then exited construction settings to re-generate the cabinet. (this took a while) I then saved the cabinet from here, closed out the room and I can now open your cabinet fine in the cabinet editor.
Sean Jakob
Thank you for taking the time to have a look at it for me
Sean
