Cabinet version 5 problems???
Audrey Racine
Post by Audrey Racine »
Hi!
I'm wondering if cabinets that have been created in version 5 will bug in the new version? I have lots of bugs with my library created in version 5 or older.... And when I try with your standard cabinets things seems to be good... Anyone have the same problem???
Company Name: Halls Edge Inc
Re: Cabinet version 5 problems???
Post by Josh Rayburn »
Audrey,
The best thing to do when bringing a cabinet from a previous version into the new version is to:
Bring the cabinet into the cabinet editor
Force a rebuild, which you can do by going to construction settings then just press OK.
If you still have trouble, do this:
Select the cabinet in the cabinet editor
Right click, go to 'Remove all part editor cuts' then 'from entire cabinet'
This will rebuild the cabinet again, and this forced a rebuild of all the part bodies in case they were lost somehow from the previous version....Of course the downside is that you must redo any part editor work you have done.
I make it a practice to take every seed cabinet that I use into the editor and do both the tasks outlined above and I have no problems, even from some really old v4 cabinets.
Hope that helps,
