Cool can we make a poll for that? Will it be noticed?I be happier, though, with the ability to add machining for metal drawers, and pulls/knobs, automatically.
ANOTHER SIGNIFICANT THING NOT PREVIOUSLY MENTIONED IN THIS POST
Changing Door Styles
I think one of the sad things here is that when you are using metal sided drawers, you are unable to utilise the "Change Door / Drawer Style" within the program.
That's right, whether it be from within layout or from the batch cabinet area, this functinoality, whilst brilliant in theory is pretty useless to those of use who are struggling with the hole pattern in the back of the drawer face problem.
You see, don't get me wrong, I'm sure all metal sided users would love to be able to use this, but the reality is that any manually placed holes into a door or drawer are lost during the process of changing door styles, so even if we have gone to the trouble of adding the holes manually, constraining them etc, we simply can afford to change the drawer style because it will take too much time to go back through and re-add all of the manually added holes.
The implication here is that those of us using metal side drawer systems generally have to create a multitude of different libraries simply to cater for different door styles. For example, I need to create an absolute minimum of 3 virtually identical libraries because I need to have doors slab style doors with 2mm edging, 1mm edging and no edging. then within each of those libraries, we need to manually add the holes to the drawer fronts in each library so we can somewhat efficiently produce a job.
I could go on an on about other implicated areas too, such as a wall over tower cabinet which has a drawer at the bottom. I end up having to create a multitude of almost identical cabinets simply because it is too cumbersome to create them on the fly. Anyway, sorry to sound like I'm bitchin, cos I ain't I would just like to see this diffulcult area bought in line with the rest of the program which is simply awesome!
