downloaded libraries
- Company Name: Can-Am CNC Creations
I have downloaded some of the libraries from the design sharing but they do not show up in the program after I install them. The computer is not hooked up to the internet so I copied the files to it from my flash drive. Do I have to do something other than unzip them and run the exe file to get them to install. I have Windows 7 pro on the new computer.
Re: downloaded libraries
I guess no one else has had this problem
Look and see whre your normal cabinets are.
Make sure the downloaded libraries are saved into the same area so you can find them.
I don't remember the string of C:/....ect off hand but someone may chime in with it.
Kenneth
Kenneth
- Kerry Fullington
David,
Your Version 6 cabinets will be in your Shared Documents Folder.
In XP the path is C:\Documents and Settings\All Users\Shared Documents\Thermwood\eCabinet Systems\Cabinets
The path is a little different in Windows 7 but look for your shared documents.
