Top Hinge Door's
Bryan J Tanner
Company Name: Decor Designz
Top Hinge Door's
Post by Bryan J Tanner »
How hard would it be to add a Top Hinge option to the Door/drawer editor?
I know you can just rename a door, but that doesn't assign the appropriate hinges when resizing.
And though I don't use it I'm sure its frustrating for those that machine hardware holes on a CNC.
Just a thought for a release sooner than later. :D
HP Pavilion DV6
NVIDIA GeForce GT 230M
Windows 7 Home Premium
Nick M Singer
Re: Top Hinge Door's
Post by Nick M Singer »
Hi Bryan. Nor sure I understand exactly what you are referring to but I assume you are talking about a cabinet with the door top hung and the door would lift up? This is easy to resolve by modifying a cabinet lying on its side so the sides become the top and deck. This way you can resize and the correct CNC info is given
Bryan J Tanner
Hi Nick,
Thats a great idea and I must say that I hadn't thought of that.
I tried it just now, and it would be great for creating batches, but I do mostly Custom Layouts.
In Custom layout this just becomes a pain in the butt. Is there something I missed?
HP Pavilion DV6
JohnLashuay
Post by JohnLashuay »
Hi Guys!
I would love to see this option as well because there are situations where I can't lay a cabinet on its side. Since we mainly do closets most of our cabinets are done with multiple sections. A tilt out hamper has its hinges on the bottom shelf and when the next section is a stack of drawers, the only work around is very time consuming.
-John
http://www.rylexonline.com
Thermwood CS 43
Nick M Singer
Bryan I dont see why this should be a pain in the butt once you have created this unit and saved it in your library. All my work is done in custom layouts and I use this solution all the time.
John i am not clear as to what you are trying to achieve, perhaps you can give an example and I may have a work-around
Dennis Englert
Post by Dennis Englert »
If you save the rotated cabinet as an assembly, I think it will minimize some of your effort.
When the cabinet is installed in either the plan or elevation view, it snaps to the wall, but installs at floor level. So you'd need to reposition it in elevation view both vertically and horizontally. Other cabinets don't snap to an assembly and assemblies don't snap to other cabinets. I think that if you needed several of these cabinets to line up, it might be easier to make an assembly of all of the uppers. Then install the whole bank of cabinets on the wall as one unit.
Just a thought,
BTW. I'd think that there might be some that would want the capability to hinge on the bottom of the door as well.
Hope it helps,
Dennis
JohnLashuay
Nick,
Here is a jpg and an hsf file that shows a hamper door which is hinged on the bottom shelf and is surrounded by drawers. I cannot do this design to be cnc'd just by rotating the cabinet. The "work around" that I use is creating a contoured pattern from a rotated cabinet.
-John
Dwr_Hamper_14x84x50_24-24.hsf
(3.44 MiB) Downloaded 899 times
Thermwood CS 43
Bryan J Tanner
Thanks guys, there is always a workaround and nothing I've found you can't do with eCabinets.
What I'm saying though is that a Top, and Bottom (Thanks Dennis) Hinge option would be good. And a practical feature to add to the software.
HP Pavilion DV6
Nick M Singer
Bryan that configuration must be exceptional in which case I would create the holes in the PE.
Bryan J Tanner
If by exceptional you mean rare, most of the kitchens I build have this style upper cabinets.
HP Pavilion DV6
Nick M Singer
Bryan I was referring to the example given by John, the solution of a cabinet on its side works just fine for upper level cabs
