Help
Wally Schneeberger
Help
I downloaded the Osbourne wood products from Kerry and also the Hardware resources but now how do I make them accessible to use in my room layouts??? I used to know how to do this but everything has changed. TIA.
Re: Help
Hey Wally, are they still in STL format? If so you will need to take them to the display part editor and give them a texture. Then save. From there you should be able to open them in the Display Objects menu.
- Kerry Fullington
Re: Help
Rick,
These are already saved as .hsf files.
Wally
You will need to place the files in your eCabinets Import directory
The path in XP is
C:\Documents and Settings\All Users\Shared Documents\Thermwood\eCabinet Systems\import
You will then be able to add these as Display Objects in the Cabinet editor or Custom Layout.
You can still take them to the Display Part editor and editor them if you want.
Wally
The path in XP is
Wally Schneeberger
Re: Help
Thanks Kerry!! You too Rick!!
