When you select Open With it should give you the option to select "Choose Program...". From there you should be able to select what ever program you use for zipped files.
To change it globally, to to your File Explorer (right click on the start button and select Explore)
In file explorer, select the Tools button and Folder Options
A new windows Opens
Attachement 1.JPG (38.04 KiB) Viewed 19235 times
Select the zip file at the bottom of the "Registered File Type" window
Then select change and a new window will open
Attachement 2.JPG (32.45 KiB) Viewed 19235 times
Click OK and close all windows.
Your Zip files should now open correctly with "WinZip" or "Compressed (zipped) Folders" or what ever your choice may be.
Sorry, I couldn't edit my last. I had to redo it to show the images
A new windows Opens
