The only problem I see with that Kerry, is when you change materials you would have to recalculate tenon thicknesses.
I never understood why full dado thickness is a static measurement and blind dado thickness is a percentage. To me it makes more sense to allow static or percentage thicknesses for both.
tenon % thickness VS. TWD thickness
- Josh Rayburn
Re: tenon % thickness VS. TWD thickness
That's right Dan, especially if you're changing thickness on the fly (i.e. on the way to the twd file)- you'll have no control over the tenon thickness. This is also a change that would have to be modified on a CE basis, one cannot do it on a job level. Lots of extra screwing around.
- Kerry Fullington
Yes,
This would need to be something performed at the job level at the control to be a solution and reading the Control Nesting Manual I didn't fine a way to do this.
- Josh Rayburn
Right Kerry - there's no way to do it at the control either. Once the twd file is created from ecabs there is nothing that can be modified anymore. (except that cool new "merge materials button!)
We have done the math equation to get to the desired tenon thickness. Besides the problem with having the tenon thickness change with any material thickness change at the TWD there is also the problem with having to do it for any material variation. Seems counterproductive. Then there's the opportunity for error with the late night arithmetic, trying to pencil it back to a direct thickness value. Seems counterproductive most of the time for how I use the software but maybe there is a benefit to the % thickness for other shops and I'm not aware of it.
