Problem Profiling!!!!
Will Williamson
Re: Problem Profiling!!!!
Post by Will Williamson »
I can get your part to profile to the straight line in the center and it will profile from the other end back to the straight line in the center
I have had a problem with these OG profiles on a complicated part edge similar to yours in the past and Tech support could not resolve the issue They even tried using ArtCam and they could not get it to work
Will
http://www.willmade.com
Will Williamson
Are you able to create DXF files of the part and profile I have a couple more Ideas but I need the DXFs
I have spent hundreds of hours on problems like this
Will
Will, I have tried a DXF of a similar shape to Kerry's, and all I could do is the straight sections using Single selection. In Partial selection, I could only select two edges.
Will,
Here is the part geometry and tool geometry in .dxf format.
Will.zip
(12.8 KiB) Downloaded 1319 times
Scott G Vaal
Post by Scott G Vaal »
Kerry,
Could I get you to attach the geometry that you used to create the .tol file. { filename.x_t }.
Thanks Scott,
Here it is.
Scott (for your eyes only)!!!
If this turns out to be my mistake or something I have done wrong we won't need to mention it on the forum. OK? :)
Base_02_test_05.zip
(4.31 KiB) Downloaded 1307 times
Scott G Vaal
LOL, it's a Deal! Let me dig into this for a while this morning and see if I can come up with anything.
I think if you would add the ability to drill holes for slide mounts in cabinet backs, it would probably fix this problem also. :lol:
Gary Campbell
Post by Gary Campbell »
I dont have a dog in this fight, but it seems Kerry has officially gone over to "the dark side". He is now one of those "needy" machinists. He seems to keep coming up with one needed feature after another, and as yet, has not gone back to school to learn programming. :lol:
Gary Campbell
Will Williamson
It looks as if this is not possible using Ecabinet. Are there other Thermwood software options that it will work on? Such as Master Cam or Art Cam
Will
Will,
I can't accept that it cannot be done in eCabinets. I can get the part to profile using a chain operation so it should also perform the partial.
I can always use wider stock, profile it as a chain operation and saw off the back side. I would like it to work properly though. Parts like this are what eCabinets has always been about.
Sounds like more pizza.
Scott G Vaal
Kerry,
Sorry for the delayed response back. I have this on the list to be looked at, especially the chain verses partial chain. I know that if a smaller diameter tool is used, it will perform better. Our 3rd party solids engine seems to not enjoy the tight corners that can cause the tool to wrap back over itself. We have several cases submitted to them in hopes that they are resolved or improved. I will try to keep you informed as I find anything more out on this. Sorry for the inconvenience.
Scott,
For your information I don't have any luck with smaller diameter tools either.
Using a partial operation I get the Sweep Operation Not Possible error with even a 1/4" diameter tool at 1/8" depth.
It of course works using a chain.
Scott G Vaal
Kerry,
Can you do a partial using this tool? { Amana Tool\AMA-56208-noBEARING.tol } This one works for me. Attach the small .tol file that you used if you don't mind.
