Light switch
Ruben Figueroa
Company Name: Figueroas Fine Custom Furnitu
Light switch
Post by Ruben Figueroa »
Is it possible to place a light switch on the cabinet instead of on the wall?
Re: Light switch
Hi Ruben, it is possible by using a Display Object. I don't have one, but I have a DXF file of a double plate if someone can convert it.
lightSwitch- Double.zip
(3.36 KiB) Downloaded 771 times
Re: Light switch
Light switchs with Plate
ws 2-plate.hsf
(116.02 KiB) Downloaded 750 times
Re: Light switch
Your the man George!
Re: Light switch
Thank You Rick
I hope it works for Ruben
Heath Doty
Company Name: Jahabow
Re: Light switch
Post by Heath Doty »
George,
I always notice lots of custom hardware/products in your image posts... do you model those externally and import them as STL files, then convert to HSF?
I've been bringing things in that way but I'm not sure I know how to get different colors/finishes applied to different surfaces of the HSFs.
Share some of your secrets with us 8)
Heath
Re: Light switch
Hi Heath
Yes I make most of them in a Cad program then turn them into Stl and put them in e-Cabinets like you said as HSF.
I find a picture on the web. then bring it into the Cad program and copy it.
If you need help on anything made in Cad let me know.
Dennis Englert
Re: Light switch
Post by Dennis Englert »
The STL files are brought into the Display Part Editor. There you can change the finish and save it as a HSF file.
Dennis
