adding hole pattern to side of draw box
Jason Stephenson
Company Name: Marks Joinery
Post by Jason Stephenson »
Trying to add some hole pattern to the side of a draw box and running into a bit of a problem, i have made a hole pattern and just cant work out how to get it from the hole pattern folder to the right side of the draw box i could put them in manually but thought you could do it quicker if you made a hole pattern
Company Name: Halls Edge Inc
Re: adding hole pattern to side of draw box
Post by Josh Rayburn »
Jason,
Does your hole pattern have a positive depth for the holes being bored into the side of the drawer box and negative depth for the holes in the case side? I have not tried it yet, but I believe this was how it was originally intended to work. I'll have to give it a go today and see if it works.
Josh,
That is the way it was intended to work but doesn't yet. Maybe in future versions.
Jason Stephenson
thanks for the advise guys put them in the part using part editor and then constraint them
