Door Materials
Jordan Skappak
- Company Name: Rainbow Contractors
Door Materials
Hi,
I have a quick question about changing door materials. Basically, I am looking to change door materials/edging globally across batched cabinets/layouts(havent played with this one much yet).
So far however I have found no way to change door material at all, aside from bringing each cabinet into the door editor -> deleting that door -> opening my default door -> changing the materials -> saving it as a new door -> make this door my new default ->placing the new door back on the cabinet.
The box colors were easy enough to change, however for my purposes, the box could stay white forever, so long as I can easily change door colors as the doors are whatever the customer wants.
I am new to these forums and to E-cabinets so go easy on me. I searched the forums for similar threads and ive gotten the impression that changing door materials is not as easy as I'm thinking it should be.
Am I missing something?
Re: Door Materials
Hi Jordan, while in Batch, check the cabinet, or cabinets you want to change. Then hover over your fly-out menu, select Adj. Features. From there you can select from the menu the changes you want. I don't think the cabinet material itself can be changed in Batch. Hope this helps.
- Josh Rayburn
Re: Door Materials
Hi guys,
You can change the doors and drawer fronts from that "adj features" button and you can change the sheet stock of all the batch cabinets by clicking on "change sheet stock" at the top of the batch list.
Even if they are 'slab doors' which are from sheet stock, they must be changed by the 'adj features' button which will prompt you to designate the door you want in the 'door and drawer front designer' dialog that follows.
JohnLashuay
Re: Door Materials
This is good to know!
Re: Door Materials
Josh, so I'm sitting here staring at it, didn't even realize it was a clickable button. learn something new every day.
- Josh Rayburn
Re: Door Materials
So do I Rick, I don't know if you saw the post but I recently discovered the right click option in the main cabinet editor for "construction" which allows you to change the joinery on a part without going into the editor. (ex. a fixed shelf)
I asked how long it has been there and Scott said since he fell off his dinosaur and broke his wooden underwear!
It has been there staring at me all this time!!
Jordan Skappak
Re: Door Materials
Well now, this is exactly what I was looking for. I don't even have to save the door as a new door, I can just change the materials on a generic door. Perfect. Thanks guys
Wally Schneeberger
Re: Door Materials
If you want to show a few different door (or material) colours on a job you can open your job and change colours and do a Save as -- different name-- then close the original job and Don't save the changes and the original is still there unchanged. FWIW.Jordan Skappak wrote:Well now, this is exactly what I was looking for. I don't even have to save the door as a new door, I can just change the materials on a generic door. Perfect. Thanks guys
Nat Wheatley
Re: Door Materials
Re: 'the right click option in the main cabinet editor for "construction" which allows you to change the joinery on a part without going into the editor. (ex. a fixed shelf)'
Does this normally work? I just tried it on a fixed shelf and an adjustable shelf, and the entered changes didn't take...
- Josh Rayburn
Re: Door Materials
Nat, did you right click on the part you were trying to change? I thought you had to select the part you wanted to change but Scott had corrected me recently and the right click has worked for me every time - it should trigger an immediate rebuild.
Nat Wheatley
Re: Door Materials
Josh,
I've tried it both ways now a number or time now, and neither has worked. When I have a chance, I'll reboot and see if that helps any.
Nat
Nat
Nat Wheatley
Re: Door Materials
FWIW, here's the cabinet I was working with.
- Test.hsf
- (1.02 MiB) Downloaded 859 times
- Kerry Fullington
Re: Door Materials
Nat,
I was able to change your center shelf to full dado using the right click menu without any paroblems.
Nat Wheatley
Re: Door Materials
I just restarted my computer and still no luck. I'm still in Beta 1, and will try Beta 2, though I don't think that's the issue. Weird.
Nat Wheatley
Re: Door Materials
Tired Beta 2, and still nothing. It works fine for the other parts of the cabinet, not the fixed or adjustable shelves.
