G803
Will Williamson
G803
Post by Will Williamson »
Can you make the G803 the default acceleration factor?
Will
http://www.willmade.com
Georgi Baltov
Re: G803
Post by Georgi Baltov »
Hi Will, you can add the code in the program header in settings. I've done it on our machines.
Will Williamson
Re: G803
Thanks Georgi is that the factor you used ?
Will
Georgi Baltov
Re: G803
Yup.
Brad McIntosh
Company Name: CNC Automation
Re: G803
Post by Brad McIntosh »
Will,
As Georgi stated you can add that G803 code to the "Header".
You can access the parameter field that via [SETTINGS] -> [SHEET MACROS].
:!: Whatever you place in either the "Header" or "Footer" section will be added to the NC program verbatim, so make sure that the commands are syntactically correct in order to avoid program errors.
Brad McIntosh
CNC Automation
Twitter: @bmcncautomation
