Lock Dado 100% thickness causes unnecessary back flips. If you make thickness 50% behaves accordingly. Interestingly, if you just do 100% dado everything OK. Is this a bug or am I missing a setting somewhere?
Thx
Fred
im having same issue i put the locked dado tennon gap at 0 and it does a flip op but only does the dado on the shelf at about 1 to 2mm deep which is painfull for us so ive just gone back to doing 100% dado and getting the assemblers to drill hole in the dado if there was a way to get around this, this would be great would save even more time for our assemblers hope this helps
