I totally agree with designing a test cabinet and adjusting the clearances as required. I would right now if I could.Will Williamson wrote:Design your self a small cabinet 12" x 12" x 12" and see for your self the result of your setting changes and flip ops
I haven't heard the term waste-board but in googling am I right that it seems to be a board you put on the CNC that the actual board you are cutting goes on top of? Even reading the threads on here about waste board I am having a hard time figuring out what it is. Nothing comes up when I enter it into the eCabinets search field in Help.Daniel Odom wrote:If the material is a different thickness than what was programmed for then the dado depth will be off. The fit clearance wouldn't be affected as the machine is referencing the bottom of the sheet and leaving the tenon thickness specified, however the joint would no longer be perfectly flush. You might get away with it if it's just a little off, but anything over a 1/32 could cause problems. The tightness of the joint is more likely to be influenced by waste-board thickness and tool length accuracy, bit flex and material flatness. The fit clearance can compensate for the variance in this regard. So for .01 to work everything would have to be set up dead on and you're machining perfectly flat material; in reality somethings always going to be a little off and you need a little room for glue too. It's also easier to assemble somewhat loose joints as opposed to perfectly tight.
The cabinet material is pre-finished only one one side. It is domestic, ie made-in-Canada (Quebec actually) 3/4" thick pre-finished flat-cut maple veneer with 120g particle board core with both the finish and the core being VOC-free and NAUF. The other side will be A3 or A4 quality which means a lesser quality veneer will be used on the other side as it will not be seen. The doors will either be MDF or pb core, slab design, veneered on both sides and supplied by the company that is doing the custom veneer pressing with sequence-matched American Walnut so that the grain is continguous and consistent across the door and drawer panels. I am not sure yet whether we are going to cut all of the doors and drawer faces on the Thermwood because I think the kerf size on the CNC drill bit might be too wide and therefore ruin the look. So, I may have the company that is custom pressing the veneer do the cutting which the don't do on a CNC but I imagine they do on a table saw.Daniel Odom wrote:You can update material thickness before sending to machine, so you don't have to go back and change every cabinet. Should work without any problems as long as the difference is only slight. If the difference is over a 1/32 you might want to update the material thickness and write a twd for the box parts but create another seperate twd without updated thickness for the door and drawer fronts if you're doing frame-less construction and verify that the door sizes to be cut are correct on the machine.
Is the material going to be finished on both sides? Might want to find out as I've run some cabs from pre-finished ply on one side and it was all I could do (or couldn't do) to get the material to vacuum down flat. Maybe it's not as much of an issue with pb core.. hopefully not anyhow. Or is this just a melamine finish on one side?
