Can't open old jobs with new build
Glenn Warner
Post by Glenn Warner »
Get a box saying "Unable to open Ecabinets file data" followed by box saying "There was an error after opening the job file". Tried to open several different jobs with same result. I can open cabinets, but the materials are not found. My user path is different from the default, which I changed in preferences. I attached a job that won't open if you want to check it.
Glenn Warner
Living cab3.esj
(2.01 MiB) Downloaded 727 times
Glenn Warner
Re: Can't open old jobs with new build
Problem is on my end. I restored my jobs from a backup and the problem went away. First I restored to the last ecabs build and the jobs wouldn't open there either. that's when I figured my job file was corrupted. hope I didn't waste too much of your time.
Glenn
