part editor release 13
Neville Bastian
Post by Neville Bastian »
Hi,
In part editor, I am able to create a cutout for a circle 5mm to 25mm and so forth but when I try to make a sink cut out it comes up with an error as attached picture will show. I didn’t have this problem before the versions build v6 ver 12 but as soon as I updated to 12 and 13 the ability to do so had gone. I have tried re-doing it I have restarted ecabinets multiple times, restarted computer and also tried on many other materials and everything with this design doesn’t work anymore.
Any help that you guys could give would be much appreciated
thanks
Regards Chris
Detailer at Classic Cabinetry
error message.jpg (21.84 KiB) Viewed 5824 times
Neville Australia
Daniel Odom
Re: part editor release 13
Post by Daniel Odom »
Looks like there is a line connecting the two outline shapes, try deleting it, pocket through the center shape and use profile modeler to create the rebated lip if that's what you're trying to do.
Scott G Vaal
Post by Scott G Vaal »
Neville,
I have reproduced the issue here and will get it listed and fixed. As a work around for now, you can widen the gap between the 2 lines so that you have a little over .1" (2.54mm) and it should perform the cut. I used .105" (2.67mm) and it worked for me. Sorry for the inconvenience.
Neville Bastian
Thanks Scott . The suggestion worked a treat so all smiles here. :wink:
Regards
Neville
Neville Australia
