line drawing editor crash
Mike Snodgrass
Post by Mike Snodgrass »
My program is crashing often when I go to print from LDE
Rick Deskins
Company Name: Thermwood
Re: line drawing editor crash
Post by Rick Deskins »
Can you post a job/cabinet that crashes in the LDE? I think we have it fixed in the current beta, but I want to make sure. Have you updated your video card driver?
Rick Deskins
Mike Snodgrass
Here is one that I'm having problems with
3718 Arthurs circle.esj
(6.94 MiB) Downloaded 1341 times
Dennis Englert
Post by Dennis Englert »
Mike,
I hate to say this but I printed all of the pages of your layout twice without any issues. I noticed that someone else downloaded your file, maybe they can chime in.
Possibly, you need to see if there are any updates for your printer drivers.
Dennis
Mike Snodgrass
Thanks Dennis
I use a different printer model at home versus shop but I'll see what I can update
Rick Deskins
If you still get the crash, can you post the error? Start ecabinets, do the steps to make it crash then hit ok to the error. Then get the error from the event viewer. The easiest way to do this is to select Start, then RUN. Type eventvwr.msc and press ENTER. Under Windows Logs, select Application, and then find the 'X' that details the problem.
You should be able to highlight the text in this window and then press <ctrl><C> to copy the text. Paste this into your post for review.
Rick Deskins
BenRatt
Post by BenRatt »
My LDE crashes whenever I try to print more than one page of a batch. I import the cabinets into the LDE as a batch and after printing the first page I get "Encountered an improper argument". I've been having this problem since the last update. Is this a known issue?
Ben Ratterree
Blue Ridge Cabinetworks
Spartanburg, SC
http://www.blueridgecabs.com
