Has anyone else had gremlins when entering doors through the batch cabinets area?
It works okay for a couple of doors then changes the sizes.
Its not a feature I have used before.
Mark McCallum wrote:Has anyone else had gremlins when entering doors through the batch cabinets area?
We see what is happening here and will have it resolved in the next version. It is a metric only issue and requires the step of changing quantity then adding another door without changing both values. As a work around, you can re-enter the height value too (even if it is the same number that is already displayed), and it will work.
Also, your video showed an issue with the view scrolling to the top each time you added a batch display item. It is suppose to scroll the view to the last item added. We will fix that as well.
FYI, another stopgap for this issue is to always press the enter key after entering in the width. (when you press enter, you will see the mm get added to the value).
