Min Pocket Leftover area for outline
Kyle Koehn
Company Name: Countryside Cabinet Shop
Post by Kyle Koehn »
Is the min pocket leftover area setting supposed to apply to the outline cut as well? I am wanting to clean up some of my right angles and it seems like this setting isn't having any affect. I am importing layered dxf into CN.
Brad McIntosh
Company Name: CNC Automation
Re: Min Pocket Leftover area for outline
Post by Brad McIntosh »
Kyle,
As far as I know... no - the "Min Pocket Leftover" applies only to POCKET operations and not to OUTLINEs.
Brad McIntosh
CNC Automation
Twitter: @bmcncautomation
Kyle Koehn
That is unfortunate. I use a 3/8 compression for my outline cuts and would like to cut the toe notch as well. The radius left by the 3/8 cutter is almost too much. Not sure its worth it if I have to clean up all the corners afterward.
Clint Buechlein
Company Name: Thermwood Corp
Post by Clint Buechlein »
Kyle,
The only way I could think to get it to do what you want is if in CV you can do the side without a toe kick notch. Then cut the notch with a pocket, but you have to leave some skin behind, usually around .005" will work. The skin is needed because if it is a through cut, it will become part of the outline. If there is skin left, it will be treated as a pocket and obey the pocketing settings. Once again, not sure if you are able to in CV, but a picture is attached below of how it's done in eCabinets. The attached nest picture, depicts the difference between the left end that wasn't modified and the right end that was.
Kyle Koehn
I was able to place a 5mm drill operation right there in the corner and then save that back into the catalog in Cabinet Vision. Got me the result that I wanted.
