When a set the ''Line Enhance'' so there are some lines that I can hide it appears to be perfect.
But when I print, all the lines appears again. Is there a way to print and get exactly the same thing?
Here is a suggestion, it would be great to be able to export in DXF the cabinets from the ''Line drawing editor''. So we could add the cabinet into a CAD software.
Audrey,
I have this same issue. Try to change your printers resolution. I have found higher res and those construction holes go away. At this point, I just print to a 1200dpi PDF and then out to my printer. Some cad programs will even bring that PDF in.
Fred
I've learned to just do a screen print then bring the screen capture into a graphics program, crop away what you don't want and print. Printing from LDE has been sketchy as long as I've used eCabs (2009).
