why when you are cutting single sided material and there are operations on the B side but nothing on the A side can't B side be face up?
your flipping the sheet for no reason.
Windows 11 Professional 64-bit http://www.trueform.ca
CS43 cnc
I would assume that the material is left as is so that there is a consistent material orientation for the operator when loading - namely "Side B Down Against the Table". If what you are asking were an option - and I think it would be a good "user selectable" option in Settings, then the operator would have to pay close attention to the "LOAD MATERIAL" messages/dialogs to insure that the material was loaded with the correct face up.
If using this possible option in "auto-loading" situations, one would have to review the material face orientations beforehand and pre-stack the bundle accordingly before starting the run.
