Hello all. We have to rout full depth 1 5/8'' grooves in a solid oak 2 3/4'' thick piece. We have a lot to do. Problem I have right now is that I get a lot of vibration due to the tool lenght I think….I'm using a 3/4'' diameter Onsrud 60-277. I have 18 grooves of 17 1/2'' long to machine on each piece, tool does not last more than 3 pieces...and most of all, I thing it's being really tough on our cnc.
You definitely need to make cuts like that in multiple depth passes. My rule of thumb is not to exceed the bit's diameter for the depth pass - i.e. you would make 3/4" depth passes. Other than that, it's just a matter of fiddling with feeds and speeds.
As a side note, on solid wood, you'll get less splintering if you do climb cuts.
I've done a fair amount of that type cutting and have best results with a 3 flute rougher hogger upshear purchased from Carolina Specialty Tool $275. By a shorter one if you can with less cutting edge. Set the tool as far into the collet without the fluting touching. I usually leave mine an 1/8" out. If you set it below the fluting it will break.
If you need a clean top edge then you will need to run a shallow pass with a downshear first.
Run the tool 16000rpm and upwards of 700 ipm. You can play with that a little but it will cut that fast easily at 3/8" depth passes. If you run it that fast you tool will last a long time.
Depending on what you're using to program with you may be able to do a constant load pocket which can spiral in and then scoop away at the pocket wall a set amount at a time instead of just running the full length at full cut if that makes sense.
What are your speeds and feeds on this job. I do this all the time on, solid wood.
I use Vortex tools with down spiral. Chip Breaker, Rougher, or finisher,
adjust tool, for needed edge surface quality. These tools last for all day.
If you need smooth edges, try a 5/8 down spiral rougher, followed by a 3/4, down spiral, finish cutter.
I usually run these cutters at 16,000 rpm, 500 IPM
Make sure you are making chips, not dust.
