Since the upgrade every time I bring a board into the part editor it gets cut off. It goes in as the entire board, but very quickly you can see more than half the board disappear from view. And it's gone dimensionally, not just hidden from view. Doesn't happen with panels or cubes, just board stock.
I see the same thing. I'll pass it along to the software engineers and go from there. It seems as though it is still there, but being rotated and cut away. You can use the Delete tool and choose Geometry Cut. The area that has been removed will show so you can bring it back. It still gets kind of weird coming out of Part Editor, but it is there at least.
Great, because I've already updated my video driver. If it wasn't that I don't know what it might be. Using panel stock is a pain because it gets nested. Thanks
I'm having this issue again. It's with a board stock. I can see how it's being rotated when I bring it into the Contour area of the part editor. I tried editing it there but it doesn't work.
It seems if I bring in cabinet parts I don't have this issue. I just tried a cube and it also doesn't have issues.
