Cabinet Numbers
Anthony Gonzales
Cabinet Numbers
Is there a way to change the cabinet #s ? I created a cultist with elevations showing the cab # now I changed 1 cabinet and that changed all the cab #s
- Clint Buechlein
Re: Cabinet Numbers
Anthony,
I'm going to go with the assumption this is a Custom Layout job? If so, you cannot. The cabinets are numbered as they are placed in the room, if a cabinet is removed from the order, the other cabinets are renumbered sequentially.
Sarah Jeffries
- Company Name: Millmade Inc
Re: Cabinet Numbers
It would be helpful if we could change the numbers.
- Kerry Fullington
Re: Cabinet Numbers
It would be great if I delete Cabinet #5 from custom layout, the number five goes with it leaving all other cabinets correctly numbered.
My solution for now is:
After creating any line drawings with cabinet numbers, I never delete a cabinet. I just pull it out of the room to a "trash bin" out of the way so the cabinet numbers are not interrupted.
