error with new update
- Company Name: JRs Woodworx
I've never had this happen with other updates, any info would be helpful. Thanks
Re: error with new update
Also, The update page on the thermwood site is still showing the old date and the download file is the old file as well? Not sure where even to get the new update otherwise.
_____________
NVME SSM2HD 1TB NTFS
Try redownloading the installer, in the event the download was corrupted. Also make sure to right click and Run as Administrator on the downloaded file just to make sure it isn't permission related.JR Allen wrote:I've never had this happen with other updates, any info would be helpful. Thanks
As far as we can see and others have reported the update is good and live. Make sure when you go to the update page to refresh it in the event your browser is storing the old page in cache. If you are using Chrome you can press CTRL+F5 to force a refresh.Stuart Douglas wrote:Also, The update page on the thermwood site is still showing the old date and the download file is the old file as well? Not sure where even to get the new update otherwise.
Got it to install from the site, thanks for the help
That was the solution! Thanks!Clint Buechlein wrote:As far as we can see and others have reported the update is good and live. Make sure when you go to the update page to refresh it in the event your browser is storing the old page in cache. If you are using Chrome you can press CTRL+F5 to force a refresh.Stuart Douglas wrote:Also, The update page on the thermwood site is still showing the old date and the download file is the old file as well? Not sure where even to get the new update otherwise.
_____________
- Company Name: Millmade Inc
After downloading and then running as administer I'm getting a window that says "Windows cannot access the specified device, path, or file. You may not have the appropriate permissions to access the item.
Sarah,Sarah Jeffries wrote:After downloading and then running as administer I'm getting a window that says "Windows cannot access the specified device, path, or file. You may not have the appropriate permissions to access the item.
Do you have eCabinets User Data Path set to a network location? If so you need to run the registry edit on the eCabinets download page.
