CN not using standard sheet sizes in addition to off-fall
Stuart Douglas
Post by Stuart Douglas »
Anyone else seeing this:
Take an eCabS job to CN. Sort for one material only. Add a piece of off-fall material manually. Nest true shape x or y and it pops errors "unable to nest..." as if the added off-fall is the only sheet available, even though the material catalog contains viable standard materials with appropriate sizes. I can nest using rectangular optimization, and it will add the standard sized sheets as necessary from the material catalog.
_____________
NVME SSM2HD 1TB NTFS
Clint Buechlein
Company Name: Thermwood Corp
Re: CN not using standard sheet sizes in addition to off-fall
Post by Clint Buechlein »
Stuart,
Seems like an odd one. Can you send and export from Control Nesting to program@thermwood.com Attn Clint?
Stuart Douglas
File Sent. Thanks for checking into it. :beer:
_____________
Clint Buechlein
Stuart,
Your Default group has Only Use Added/Off-Fall Sheets When Available checked. This group is being used for the 3/4 Melamine Frosty white material in the job your export contained. When that option is checked, Control Nesting will only nest on added or off-fall sheets.
There is still an issue in consistency to Rectangular Optimization that the software engineer will need to look at so I'll get that reported. This is such a rarely used setting I'm not surprised no one has run into it for rectangular nesting.
Stuart Douglas
Lol, I'm getting very good at his "operator error" thing. 8)
I'm still getting used to the overrides in the last CN release, but those are a godsend, Keep up the good work :beer:
_____________
