Good evening.
We are getting the following error: Siemens feed module fault (via profibus)
Z axis feed module faulted.
Also on the Siemens encoder inside the cabinet the red light is on.
If I unplug the profibus cable from the pci card the red fault light on the encoder stay off.
Any ideas?
The error code on the Siemens encoder reads: E A504
Thanks in advance
Marius
Have you been able to resolve this issue?
I have had a similar issue on my Model 40.
Removing the profibus card ( the one in the PCI slot with purple cable ) and reseating it could help.
Sometimes there is just a bad connection.
This could happen if the control cabinet was moved or bumped by mistake.
Hello Rayno
I took the pci card out about 3 times, spray and clean it with "Electro Kleen". As soon as the super Control start up, the fault light on the Siemens profibus (encoder) comes on.
This is also a C40 model, that Jireh bought new from Thermwood in 2006.
I tried to move the pci card to another pci slot, but then you need the drivers again, which I do not have. I will have a look on the internet for the drivers.
We are trying now to get another card to test.
Hi all, I'm relatively new to the board so pardon me if it isn't best practice to post a reply into a thread as old as this one, but this is the only I could find that referenced A-504 A504 Siemens Drive error. We have been getting A-507 A507 for some time but this is a new one today that happened during a tool measure, the lockout happened right after the tool measured successfully when the Z axis began to retract a mm or two. I understand the A507 is a Z axis error so given when this error occurred i suspect these might be related. Was there any resolution to this thread that may be of help? Or anyone else with some wisdom on this?
