Nesting error
Chris Say
Nesting error
Post by Chris Say »
I loaded a job with part editor cuts and display panels and as soon as I click ok I get an error saying \"Data type conversion error\". What does this mean and what do I need to do to fix it? Here is the file if it helps.
Jason Susnjara
Post by Jason Susnjara »
Chris,
Are you getting this error in eCabinets or Control Nesting at the machine?
thanks,
Chris Say
Post by Chris Say »
I am getting this error at the machine. I got a will not nest this part error in ecabinets for the left-right stretcher. When filtered, it nested correctly. I made it in build 9. I regenerated it in build 10 and resaved it and get the same error at the machine. Now when I nest it in ecabinets it shows the nest for a brief second then the nest diagrams disappear.
Jason Susnjara
Hi Chris,
I just emailed you two files and they seem to work now. Try them and let me know how they worked.
thanks,
PlatinumDave
Company Name: Platinum Kitchens
Re: Nesting error
Post by PlatinumDave »
Hey Gentleman. I am getting the same error today for the first time on our CS45 Machine. Any words of advice to resolve this?
Dave
PlatinumDave
Re: Nesting error
Quick update.
As I try to nest now it just simply hangs and then after 30 minutes crashes thermwood all together.
Jeremy Schiffer
Re: Nesting error
Post by Jeremy Schiffer »
Are you able to nest any other jobs? Is it just doing it with one particular job?
CS-41 4x8
CS-45 5x12
PlatinumDave
Re: Nesting error
Hey Jeremey, thanks for reaching out! It is only this one job that gives that error. I have never seen it before. And am cutting another job today that nested perfectly, wrote and is cutting now.
