Problem trying to load job
Re: Problem trying to load job
So much for my idea. Gary just informed me that the link doesn't have the ability to toggle pocket operations for tools.
Gary Campbell
Post by Gary Campbell »
To add to this....
Scott Vaal just emailed me with info on the user error. My pocket tool was set up as a .374 dia. No doubt this will not cut the .25 pocket. For some reason I didnt realize that pocket tools were not sorted, like rout/dado tools.
So in my case, it was a user error, applying a pocket larger than the tool defined to cut it. :wall: Hopefully John's is as easy to fix.
Gary Campbell
Brad McIntosh
Company Name: CNC Automation
Post by Brad McIntosh »
A-Ha! So it was a pocketing tool definition issue!
It appears that the Shopbot link still uses the single POCKET TOOL DIAMETER definition in the "Settings" screen and does not yet have the POCKET operation classification in the "Tooling" screen as is found in the more recent Control Nesting releases.
Hopefully this will help John as well....
Brad McIntosh
CNC Automation
Twitter: @bmcncautomation
Gary Campbell
Brad...
For some reason this has not surfaced for me in the past. Speaking of the prior versions of CN, due to their similarities with the SB Link, is there only one option for a pocketing tool?
I am guessing that since I set a .374 tool as a pocket tool (no tool #), that the 1st tool operation that has that diameter and has rout/dado checked will cut the pockets? I use a good number of PE cut thru geometries, along with an occasional need for a tambour slot. my currently selected tool 3/8 dn spiral does more thru cuts than pockets. Dont s'pose there is a way to get multiple tools selected parametrically?
Gary Campbell
