Dan, thank you kind sir for your time, I have a couple appointments and then will work on this.
Hi Brian,
Yes same builds, same updates, something weird happened because I have done exactly what I am trying to do several times before with 0 problems.. I will try Dans idea before I dump and reload, or maybe I will open the window and throw it in the ever increasing pile of snow in my parking lot!!!
Thanks Dan, I will try that later,appreciate your help, send me a file some time and I will cut it up for free for you, I doubt I will ever be able to help you with any e-cabs problems..
Hi Brian, yes all the same versions, I have done this several times, that is why I beleive I must have some bad files somewhere,just cant find them.
Thanks for your reply
Never did aquire the taste for coffee, but I can put the hurts on hot chocolate on days like this, and yes we got the snow, 15 inches overnight earlier in the week with some really nasty winds, the whole area was shut down for two days, and now we a getting it again! Bet you dont have $1000 dollars in snow plowing overhead for this yr do you Dan!!!That never helps the ole budgett.....Thanks again for your help, and dont forget the offer for cutting, you have been a great help to everyone with your knowledge. You remind me of some of those guys in fine woodworking, you read there bio in the front and most of them have masters degree is some very technical field and here they are building wood stuff.
