O.K.
I did not start this, but I must contribute...
In my younger days I worked for a general contractor,Total Erection..
Imagine taking that check to the bank and handing it to the cute little teller...
5.2 build 1
Re: 5.2 build 1
Mike Murray
mike@versatilecabinet.com
Re: 5.2 build 1
Thanks Dennis, I realize that is a new feature but I guess I am referring to the render in wire frame while moving. It is an old function that I need because of the slower video card I have in my system. When you use the sliders to rotate the rendering it will go into wire frame mode but when you use the mouse to rotate it rarely goes in. Sometimes it does but can't figure out what makes it do so. It always went into wire frame mode on v5.1 when using the mouse to rotate.
Dell Precision 7710
NVIDIA Quadro M3000M
512 GB PCIe NVMe - M.2 SSD
Win 7 Pro 64-bit
http://lrgwood.com
Win 7 Pro 64-bit
http://lrgwood.com
Re: 5.2 build 1
You seem to have better results than I. Couldn't get it to "wireframe while moving" at all. Also, did not work with the sliders for me.
I'll send an email to the programmers to report this.
Re: 5.2 build 1
In the past version you could render in wireframe, which was good on big jobs.
Re: 5.2 build 1
The programmers were able to duplicate what you and I've indicated, so it's on the "repair list".
Re: 5.2 build 1
Gotta nother one for you to check out. When you save the job, in earlier versions it would save the settings you had for the render. Say, you had 2 walls hidden and the lighting hidden. When you save this, these parameters would also be saved. Now it doesn't seem to do this. I have to delete the walls everytime I go to re render after doing some editing. And I have to hide the lighting. I don't know if it unchecks all the boxes or not, but it does uncheck the hide lighting box. Thanks. So far I like this version a lot. Having everything in the one area speeds things up.
Dell Precision 7710
Win 7 Pro 64-bit
http://lrgwood.com
Win 7 Pro 64-bit
http://lrgwood.com
