hardware holes in corner cab
Jim Carter
Company Name: Jim Carter Corp.
Post by Jim Carter »
Hello
Can some one tell me why the holes for the hinge mounting plate are not applied to the corner cabinet side?
Jim
corner angled front.hsf
(576.02 KiB) Downloaded 381 times
jim@jimcartercorp.com
973-224-0221
Ringwood, New Jersey
Nat Wheatley
Re: hardware holes in corner cab
Post by Nat Wheatley »
Jim,
Increasing the depth of the holes should get them to show up on your cabinet. You'll have to play around with the entered depth to get the actual dilled depth that you're looking for. Once the holes do show up, the depth shown in the ecabinets nest diagrams should be the depth that you end up when you do drill them.
For one of my angled cabinets, I had to enter a drill depth of 18.96mm to get the holes to display, and drill at 9.5mm.
Jim Carter
Thank you Nat:
I did it as you said.
JIm
973-224-0221
