V6 glitch?
jason galbraith
Country: AUSTRALIA
V6 glitch?
Post by jason galbraith »
When i rename cabinets in batch cabinets eg i might change the name from "600 draws" to "draws main room" before i send it to the nest, i have to click on the amount button before it applies the name.
Not sure if this is unique, but maybe a glitch thread should be made, to report and hopefully fix any issues.
Apart from being able to put the cabinet library in different locations, and my screen real estate being used up in cabinet editor(not good, especially for 17 inch monitors) I've yet to see a vast difference in the upgrade. Maybe it will suit others needs better.
But congrats on finally getting it out there.
www.eastcoastultimate.com.au
Joe Dusel
Re: V6 glitch?
Post by Joe Dusel »
How many 17 inch monitors are you using? If the answer is one it might be a good idea to buy a second monitor. You can pick up another 17" monitor for about $100 these days, and a second monitor is something hard to do without once you are used to it. I am writing this on my second (21") monitor with eCabs running on the first (23"). This will definitely help with you "real estate" problem since you can now select the icon to detach the placement dialog and move it to your second screen. If you do not have a second monitor yet you can also click on the thumbtack icon when you want to hide the placement dialog.
Joe
CFT411 http://www.cft411.com
jason galbraith
Country: AUSTRALIA
Re: V6 glitch?
Yes thanks for the info. I run two 24 inch monitors at home myself. Unpinned it's much better. I only work here, getting the boss to get another monitor might take a long time:)
Joe Dusel
Re: V6 glitch?
Post by Joe Dusel »
If I were your boss I think it would be a small investment to make you more productive.
Take care,
Joe
jason galbraith
Country: AUSTRALIA
Re: V6 glitch?
Thanks Joe, I'm sure i could be more productive with a single 27-30 inch DELL monitor. Could you talk him into it for me please? :)
