Part Editor
Dan Calvert
Company Name: Calvert Custom Cabinetry
Part Editor
Post by Dan Calvert »
When trying to load a dxf file into PE to create a part ecabinets locks up. This same procedure is still working on my desktop which still has version 5 running. Anyone else tried this yet with version 6?
Everything else is running fine so far with version 6.
Rick Deskins
Company Name: Thermwood
Re: Part Editor
Post by Rick Deskins »
Can you post the dxf file?
Rick Deskins
Dan Calvert
Re: Part Editor
I don't seem to be able to load a dxf file. I get a note stating the dxf extension is not allowed. I can email it to you. The file I created was a simple 2
D design made in Quickcad from Autodesk which is an autocad based program.
Dan
Rick Deskins
Re: Part Editor
You can zip the file, then post it.
Rick Deskins
Dan Calvert
Re: Part Editor
Rick,
I am not ignoring you I am having troubles with getting a activation code for Winzip. As soon as I get the code I will zip the file.
Dan
Re: Part Editor
Dan,
Right click on your file then choose Send to then Compressed folder and that will zip it without winzip.
Dan Calvert
Re: Part Editor
Kelly,
Here is the file. It is not anything in particular just something I created to practice making dxf files.
practice panel.zip
(5.29 KiB) Downloaded 458 times
Company Name: Halls Edge Inc
Re: Part Editor
Post by Josh Rayburn »
I have no problems with the DXF file being overlayed on a part here.
Dan Calvert
Re: Part Editor
I too was able to use the dxf file on my computer with version 5 still installed it is only when I use it on my computer using version 6. I quess this eliminates the file as the problem. I must have a problem with the installation of version 6 however, everything else seems to be running fine. At least so far. Does anyone suggest that I try reinstalling version 6?
Dan
