Pull Out Drawers
Nat Wheatley
Pull Out Drawers
Post by Nat Wheatley »
It is possible to add these behind a door(s)?
Re: Pull Out Drawers
Nat,
Just use the Drawer Box Editor (Icon just right of the Part Editor)instead of the Door/Drawer Front Editor
Nat Wheatley
Thanks Kerry.
Bill Lumley
Company Name: Bills Custom Cabinets
Post by Bill Lumley »
Is there a way to put line bored holes in the cabinet side to allow positioning of the pullout by the customer . Adding drawers seems to assume a single location for the drawer .
I would like to add the drawer drillings every say 32 mm to the sides and place as many pullout as allocated to the drawer .
Thanks Bill
Rick Deskins
Company Name: Thermwood
Post by Rick Deskins »
You can use the part editor to add your drill holes and then add constraints using the Constraint Manager to keep the holes where you want them when resizing the cabinet.
Rick Deskins
Nat Wheatley
Bill,
I haven't tried it, but would guess that you could also set up a hole pattern for a pull out slide that had multiple rows of slide holes, spaced 32 mm vertically.
Nat
Bill Lumley
Thanks Guys . some good ideas there that I think should work . I dread drilling line boring holes in a tall cabinet as a pantry is ususally where I would want to do something like this but this should
give the customer some flexbility and keep holes to a minimum .
Bill
